richardthatcher Posted August 25, 2013 Posted August 25, 2013 Having a real scratch head moment with this. Defaulted panel New keypad New wire New panel All in the above order and still getting same error from time to time. Any ideas?
MrHappy Posted August 25, 2013 Posted August 25, 2013 pulled the log out with wintex ? Mr Veritas God
richardthatcher Posted August 25, 2013 Author Posted August 25, 2013 I have it on laptop but not looked yet
breff Posted August 25, 2013 Posted August 25, 2013 How many keypads on system and/or expanders The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
richardthatcher Posted August 25, 2013 Author Posted August 25, 2013 No expanded just 1 keypad Excuse the spelling iPad thinks it knows best
breff Posted August 25, 2013 Posted August 25, 2013 What about keypad dipswitch, I know manual says that if all switches are off its the same as being set to address 1 but I always set dipswitch 1 to on. Scratching really as it seems you have changed everything, seems to point to some sort of interference like rf or mains The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Rulland Posted August 26, 2013 Posted August 26, 2013 Do you get a warning for calling someone a "Dipswitch" ?.......)
richardthatcher Posted August 26, 2013 Author Posted August 26, 2013 What about keypad dipswitch, I know manual says that if all switches are off its the same as being set to address 1 but I always set dipswitch 1 to on. Scratching really as it seems you have changed everything, seems to point to some sort of interference like rf or mains They are all down
sixwheeledbeast Posted August 26, 2013 Posted August 26, 2013 What about keypad dipswitch, I know manual says that if all switches are off its the same as being set to address 1 but I always set dipswitch 1 to on. Oddly enough I do the same. Yes a very odd fault and it seems the only constant is the environment. Have you tested the removed kit on the bench?
