Gethers Posted September 2, 2013 Posted September 2, 2013 Can anyone tell me how to register new wireless key fobs (TCC8M) to a Honeywell Galaxy 2 system please? Thanks in anticipation. Quote
GalaxyGuy Posted September 2, 2013 Posted September 2, 2013 Enter master code.42.1 (Program users)Select a user account and 'ent'Select option 5 (RF Fob)Press '*'Then press any key on the fob to populate the serial number. Quote
Gethers Posted September 3, 2013 Author Posted September 3, 2013 Many thanks for your prompt response GalaxyGuy - very helpful. Quote
nimeshc1986 Posted February 16, 2016 Posted February 16, 2016 (edited) Enter master code. 42.1 (Program users) Select a user account and 'ent' Select option 5 (RF Fob) Press '*' Then press any key on the fob to populate the serial number. Hi mate, how can I add a Honeywell wireless panic alarm for the Galaxy G2-44? (TCBPA8M-1) I already have two RF Portals (37 zones currently) Obviously the PA needs to work at anytime. It worked previously when I had the G2-20 panel but recently upgraded to the G2-44 and forgot how I did it. Thanks in advance Edited February 16, 2016 by nimeshc1986 Quote
al-yeti Posted February 16, 2016 Posted February 16, 2016 Option enable pa I think in rf options Quote
nimeshc1986 Posted February 17, 2016 Posted February 17, 2016 Option enable pa I think in rf options Thanks for your reply mate. When I went home I did the following but it didn't work. Enter master code. 42.1 (Program users) Select a user account and 'ent' Select option 5 (RF Fob) Press '*' Then press any key on the fob to populate the serial number The above all worked fine but when I pressed the panic alarm button, the lights would flash but nothing else. With regards to selecting a user account to assign the fob to. I created a new user and assigned the fob to that. Is that right? or should I have selected an existing user and assigned it under them. I have also replaced the batteries so I know its not that. Also looking at option 50 (engineer), there is a hot key option. Does this need to be enabled? Thanks in advance Quote
GalaxyGuy Posted February 17, 2016 Posted February 17, 2016 You need to set these options too: Menu 51.13.1 - On + Key Fob Panic Menu 51.13.2 - Audible Panic Quote
nimeshc1986 Posted February 17, 2016 Posted February 17, 2016 Thank you guys I will give it a go when I get home from work. I will let you know how I got on. Thanks Quote
al-yeti Posted February 17, 2016 Posted February 17, 2016 Thanks for your reply mate. When I went home I did the following but it didn't work. Enter master code. 42.1 (Program users) Select a user account and 'ent' Select option 5 (RF Fob) Press '*' Then press any key on the fob to populate the serial number The above all worked fine but when I pressed the panic alarm button, the lights would flash but nothing else. With regards to selecting a user account to assign the fob to. I created a new user and assigned the fob to that. Is that right? or should I have selected an existing user and assigned it under them. I have also replaced the batteries so I know its not that. Also looking at option 50 (engineer), there is a hot key option. Does this need to be enabled? Thanks in advance Ok but it's not what I said , as galaxyguy gave more detail that will fix it, as the options has to enable the function to work in the settings Quote
nimeshc1986 Posted February 18, 2016 Posted February 18, 2016 Ok but it's not what I said , as galaxyguy gave more detail that will fix it, as the options has to enable the function to work in the settings Thank you to everyone who helped me. The panic alarms are all working fine. Regards Quote
