screened 6 core cable
Guest livewire
Guest livewire
Could someone please advise where can I order some screened 6 core cable from.
Tried a few suppliers, but to no avail. only standard they keep in stock.
I am just re-wiring my system and since I am not able to avoid proximity of some of the mains cables have to go for the screened type...
rgds
Guest livewire
rgds
22717[/snapback]
Ooops! I should have placed this in general queries, could admin do so please?
thanks!
i find screened cable the source of most problems..
Guest livewire
22725[/snapback]
Any other suggestion then?
As I said I am unable to avoid crossing mains wires under the floor boards.
Is there any other cable that would be suitable?
I must admit I had a standard 6 core cable installed for years and had no problems with false alarms even though that it run next to or been crossing mains cables. Now I need to install sensors in additional locations, so a bit more concerned about this issue since I read here on the forum about it?
when crossing a mains cable bend the cable over at right angles..
To be honest, and I'll probably get flamed for this, but induced a/c is only really a problem for poor quality panels and passives.
As long as you're using good quality stuff you really should'nt need screened cable on a domestic installation, unless the cable is carrying data. On longer cable runs EMI is more of a problem than a/c.
I would use eight core is you need six and earth the spares. Just before you put the lid on measure the induced a/c and make a note of it. If you then have an fa then re-measure and fit an ACT1313 if you want.
Guest livewire
thanks for your help!
I take this should not be an issue with Scanny 9751, I may also look into getting an expander for wireless for this panel.
IIRC most scanny panels deal with induced a/c anyway.
And avoid wirefree unless the site makes cabling impossible.
  • 4 weeks later...
22725[/snapback]
Few tips to get rid of this kind of problems:
1) Use safety isolated transformers (like LF9968) :yes:
2) Do NOT put them into any casing :no:
Now you will have safe voltage and panel/casing don't have to be earthed!
3) Use screened cables. :yes:
4) Connect screens to the panel earthing pin and/or casing (DO :no: NOT earth them)
5) When you continue wiring, don't forget to connect screens together :!:
This will cause screened cables to have its own capasitive mass.
Earthing screened cables will absolutely cause troubles due to earthing current, which causes the noise.
This is how I do it. No problems having alarm cables running next to 300Amps 230/400V AC cable.
