scantronic 9600 install manual
Guest angellonewolf
Guest angellonewolf
i would like to give thanks for any help in advance
i am working in a shop with a 9600 panel i have the user guide
and i find i need the installer manual as i am going to need to reset the
board to factory defaults as the code for the board has been lost and forgoten
i know how to do the reset but i have been told i realy could do with the
install manual as i will need to setup all of the entry exit and all zones
if i do a reset is the defaults of the system able run normaly or will i have to set other things up
again thanks for you help
Guest angellonewolf
ok sorry did not know on this do you know if i reset the system is it will
work with out any other setings i am a sparky and have had this problem be for
and reset the item and had no problems but better ask now than try to !!!!
thanks
thanks
22840[/snapback]
Unfortunately it is unlikely that the panel will behave as you want it to - for example, if you have less than 8 zones, the panel will see any unused zones as violated and will not let you set the system.
Also, your entry/exit and walk-through zones will need to be programmed or you will generate an alarm condition every time you open up!
D7
