RichL Posted September 19, 2013 Posted September 19, 2013 Customer has lost their keys. Dynamic have sugested drilling the lock out, and they can supply a new lock with 2 keys. Not done this before and Id expect the lock to be at least as hard as the drill bits. Anyone suggest the correct drill bit size, and how long its likely to take to do? Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
Cubit Posted September 19, 2013 Posted September 19, 2013 On 19/09/2013 at 11:58, RichL said: Customer has lost their keys. Dynamic have sugested drilling the lock out, and they can supply a new lock with 2 keys. Not done this before and Id expect the lock to be at least as hard as the drill bits. Anyone suggest the correct drill bit size, and how long its likely to take to do? When drilling them type of locks i find it best to start small and work your way up in size. Usually no need to drill right through, the pins start failing before then and the lock can then be turned manually.
RichL Posted September 19, 2013 Author Posted September 19, 2013 Good man. Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
Cubit Posted September 19, 2013 Posted September 19, 2013 On 19/09/2013 at 12:32, RichL said: Good man. And don't use your best bits on the small ones.
RichL Posted September 19, 2013 Author Posted September 19, 2013 Just been told its a round key, as in this link http://www.cctvdirect.co.uk/products/Haydon-Lockable-DVR-Enclosure.html?gclid=CKaBq8rd17kCFeGWtAoduQcA3w is it still drillable? Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
norman Posted September 19, 2013 Posted September 19, 2013 http://www.youtube.com/watch?v=LahDQ2ZQ3e0 Nothing is foolproof to a sufficiently talented fool.
Cubit Posted September 19, 2013 Posted September 19, 2013 On 19/09/2013 at 15:03, RichL said: Just been told its a round key, as in this link http://www.cctvdirect.co.uk/products/Haydon-Lockable-DVR-Enclosure.html?gclid=CKaBq8rd17kCFeGWtAoduQcA3w is it still drillable? yep.
RichL Posted September 19, 2013 Author Posted September 19, 2013 ******* hippies. On 19/09/2013 at 15:07, norman said: http://www.youtube.com/watch?v=LahDQ2ZQ3e0 On 19/09/2013 at 15:12, Cubit said: yep. Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
sixwheeledbeast Posted September 19, 2013 Posted September 19, 2013 Last time I did one of these I used a bit the same size as the centre circle of the lock (~7mm). Then once most of the way through all the brass pins fail out and it will open with a large flat screwdriver.
datadiffusion Posted September 19, 2013 Posted September 19, 2013 I reckon it was you what broke into H's iwise job... So, I've decided to take my work back underground.... to stop it falling into the wrong hands
