5 hours ago, Derek Foote said:
I changed the four inputs triggers on the speech dialler from active low (LED on) to active high(LED of). All that happened was that the speech dialler instantly went in to the dialling sequence.
So it means it was correct in first place
What is your trigger connected to?
I think you have trigger on the set terminal when it should be connected to the bell - minus trigger , it will dial when bell triggers
I have taken some photos of the wiring, I hope this helps to understand what I have done.
Photo 1, overall view of the Accenta G4 panel
Photo 2, Outside box connection on panel
Photo 3, connection to outside box
Photo 4, connection of speech dialler on panel
Photo 5, connection to speech dialler
Photo 6 wiring diagram for outside box as shown in Accents manual
Photo 7 wiring diagram for speech dialler as shown in speech dialler manual
Photo 8 connection of keypad on panel
Photo 9 connection to key panel
I have just looked at what i have sent and it looks like they have not been sent in the sam order that i loaded them. will try and sort them out.
As James said , take all the triggers off , and as I said before , your using the set terminal which is a hassle on a dialler
Just use one trigger and connect it to the bell trig
Ip1 to trig on panel I can't work out your pictures lol you only need to look at bell connections on ala panel and inputs on the dialler if everything else is connected ok
I have now numbered the photos of the wiring, I hope this helps to understand what I have done.
