Advice Please
uwave
I you are into the old style computer stuff I have a large collection of the old platform magazines on my web server. Feel free to download if you're interested.
http://81.168.26.21/RetroComputingMagazines/
Thanks Matthew, I will have a look. That will be todays productivity reduced then ;)
Oh dear, there is Sinclair stuff up there as well. See your tomorrow... ;)
When I originally put them up there my poor FTTC connection at home got it's upload capabilities tested. The full lot is around 140Gb and when so many users tried to pull them down it kept it at max upstream for a few weeks :)
No harder than stealing keys + fob!
Difference is you know when your fob/keys are missing, so can take action.
Also many will use the same code for all sorts like chip and pin number etc, so putting pin numbers in web browser is bad idea IMO.
Also as CG points out, pins are easier to crack. For example encrypt 8 numbers in DES.
If "hacker" knows they are only numbers (ie PIN code) this could be cracked in minutes, whereas alphanumeric cracking would take a lot longer.
