Access Control To Grant Pc Access
JasonOfOz
log on account codes is best idea but not infalible, bit left of centre but why not use a door interface to break the keyboard usb port connections? you would need to remove access to other usb ports, but present a valid card if switches state and restores the keyboard.
Cant you integrate into active directory and do it that way?
I read the op as a standalone pc, not on a domain.
Found this online for coin operated pc, could use door controller relay instead
Thanks James but using Active Directory would suggest that they were issued with accounts to start with.
As it's quite a transient workforce, they may be issued with access cards (to do their job) but not PC access.
Good thought though!
Thanks for all the great suggestions everyone.
I'm still having a play and will let you know which one comes up trumps!
Love these forums - just shows that nothing is really new and that someone, somewhere has done it before :)
