Risco Agility 3
paul44
Has anyone been using these and found problems with the camera pirs having poor signal,  keypad not connecting first time, and the panel not sending out test calls on the follow me.
Keep it that way
You have a lot of negative comments about a product range you don't appear to have used.
Odd how many others don't seem to have a problem with the kit.
I have an estate of them which I think I previously mentioned. Failure of parts of it is higher than I like.
I have an estate if them which I think I previously mentioned. Failure of parts of it is higher than I like.
Ah, one of your cheap as chips purchases and where you don't wax lyrical in glowing terms about the quality of installs/management, in fact, anything.
Even people on here who use it refer to it as Risco tat!
True, but hardly a good statistically accurate reflection of the market.
However, to even things out. I won't touch anything Honeywell. Complete s***e.
Indeed. Just about to make another acquisition that is a Risk o lover. To be fair cubit it's all wireless so danny DIY would struggle to mess up installation of it? You could practically sell it direct to end user with a tub of no more nails to fit it. The simplicity of its design I have no issue with. It's the call outs when it goes wrong that I have issues with and they can be quite frequent compared to other wireless kit we have.
