Risco Agility 3
paul44
It's very impressive. We have put it in place where traditional 2 way with repeaters failed miserably. It just works. We had issues with it when in hybrid node but in always awake not a problem.
Considerably more faith in the 12w than an enforcer.
No problem with that and I would loved to be proved wrong.
If it works out the box and no updates involved then good one texecom!
Yeah like a sad t**t I took copious pics of an R8 box I took out last week before doing my usual ebay-for-charity disposal.
Kind of saw nothing was fitting without a lot of Prosol hotknife action....
You can fit a Webway and a 1.2ah battery but only just. Nice little ledge on the top for the tbar. Ill post a picture of my amazing butchery skills.
I've not got around to putting it through its paces but I will and happily share. We have ricochet in production use and the small numbers of them we have are working well in harsh environments. Be very keen to see what udl over GPRS is like and the app with a Webway working.
Indeed. Just about to make another acquisition that is a Risk o lover. To be fair cubit it's all wireless so danny DIY would struggle to mess up installation of it? You could practically sell it direct to end user with a tub of no more nails to fit it. The simplicity of its design I have no issue with. It's the call outs when it goes wrong that I have issues with and they can be quite frequent compared to other wireless kit we have.
tbf Matt, Danny DIY can gook up any panel, it is the pro installer to state that is what you are paying for - i.e. professionalism. the Agility is a very sophisticated bit of kit, but like any kit that is installed poorly will usually result in poor results - simple as,
So i suggest stop buying up Danny PJ estates to increase your contract portfolio, whilst moaning with great big crocodile tears that your not making a fast buck out of it, at least call in a trained product specialist professional to put them right - or ho on a training coarse - it 's FREE!
I install the same kit as Arf and installed correctly it does no cause problems. Risco have come a long way in the past couple of years.
Agility sophisticated. Compared to what, a relay?
The companies we are going through acquisition of are all inspectorate approved ones, not DIY estates.
Funny really considering how many times you fecked up the simple task of clamping.
Oh, hang on a minute, we forget the legal issues you conveniently put to one side in your claim to be compliant.
Soz Arf soliciting is always illegal :)
Be interesting to see if the GPRS interferes with the Texe wireless though? I did bench trials with the iOn yonks back and it did NOT like the Webway being
in the same case.... (permanent Supervision fault)
I did a double take at the 1.2AH battery but then remembered its a wireless panel, and, assuming contacts only on the 4 wired (or my fave IR120s taking 9mA)
coupled with a fresh board design, assume that would actually last quite a while? Haven't looked at the panel quiescent yet.
Also I assume were still talking fullsize board and with the mini it would be slightly more happy days?
The only reason GPRS will interfere with the radio is if you put the antenna lead for the GPRS right next to the antennas, it will be the same for all panels not just ours, the power output of the GPR, canm cause issues, Simply route the GPRS antenna cable on te opposite side of the box and problem solved.
amealing@texe.com
Head of Industry Affairs
Visit Our Website
Texecom
