Crow PIR wired version?
Guest livewire
Guest livewire
Has anyone used these Crow wired PIR's (pls see the pic) with Scantronic 9751 panel and would you recommend them please?
I havnt used that model in the pic but I have used thousands of crow PIRs over the years and they are excellent. The housings are a bit on the big side, but the reliability and build quality are excellent.
Used loads of Crow Genius Pirs, good kit.
One of the companies I worked for before fitted the Crow PIRs. Very reliable. Only thing we found a bit of putting especially when fitted in a domestic was the LED was mega bright. :D:D
cheers Kev
Guest livewire
One of the companies I worked for before fitted the Crow PIRs. Very reliable. Only thing we found a bit of putting especially when fitted in a domestic was the LED was mega bright. :D  :D
23084[/snapback]
Thanks for your input guys.
Can always press the LED with hot iron quickly to kill that brightness off LOL ! :w00t:
22986[/snapback]
THIS VERY OLD .
ASK ABOUT MR 110
MACIEK
Guest livewire
Did not go for Crows at the end due to their size, got some Scantronic PIR's instead.
rgds
Crow is excellent kit but a tad big for the usual domestic installation. have a browse through here for some info.
