smoke cloak
Excellent!
Where else would you get that sort of information?!
Guest IM_Alarms
That wasn't very clear though was it? :D:D:D
That wasn't very clear though was it? :D  :D  :D
23339[/snapback]
Bit like the smoke I guess!! :D (or at leat you'd hope so!)
cheers
-Dan
I have fitted hundred of Smokescreen and I am Smokecloak trained. As an installation engineer, Ihave witnessed residue and wet smoke from smoke cloakes and seen what happens when batteries are taken out of smokecloaks. if you call ATC meters and ask for information on heat and batteries, they will tell you the safe opperating tempretures of batteries. I bet it isnt what they under goin a smoke cloak. this I must add hasnt happened with smokescreen I have fitted.
Thanks for reading my posts, however insane they may be.
Just remember, 'Success is Built on Commitment, Hard Work, saying F**K it once in a while and most of all LUCK'. Be Happy
simon@sgssystems.com
SGS Systems Web Site
