Optima Xm Wiring Query
Hello all,
I had to replace the battery on my Optima XM. Seems fine powered up, NVRAM retained the code and I have a 'day' LED on.
However, to disconnect the mains I disconnected the 2 blue transformer wires from the mains terminal.
Pic here:
post-6868-0-61186500-1383230426_thumb.jp
note 2 blue wires on left unconnected.
Unfortunately the pic I took before disconnection is corrupt!
I'm not sure which blue wire is +ve or -ve, or if it matters.
Can anyone help?
Thanks for your time,
IA
Better to just pull the internal or external fuse for functional isolation.
Be very careful around mains electricity, if you are not a qualified electrician.
If you don't want to use a professional, turn off the power at the mains, and connect
the two blue wires either way round. There is no polarity for an AC transformer of this type.
Yeah, not really a good idea to remove those wires.
A shock from any of them terminals could kill.
Also noticed the panels earth wire is cut off which isn't good either, not to mention the missing tampers on the zones and bell...
Not going to win compliant panel of the year award . . .
Spotted, esp. tampers, but just thought, whats the point....
True, but if its a placcy case and OP doesn't know what they're doing, perhaps best left undisturbed :)
Cable will still have cpc to point of entry, not how you or I would do it of course.
