JregGT Posted November 6, 2013 Author Posted November 6, 2013 Yup, I can go through all back to the first at 4 this morning, can go further, but just says set then unset etc over the last x amount. It just reads as PIR (then the device) of which all 5 are present at some point and the time it occurred. Each time it just says check. Rich
datadiffusion Posted November 6, 2013 Posted November 6, 2013 Ah brings it all back, I remember the 'A!' and the 'T!' but L! as a suffix?? So, I've decided to take my work back underground.... to stop it falling into the wrong hands
Alarm Protection Posted November 6, 2013 Posted November 6, 2013 Go to the keypad and check the log. Replace all batteries and wait 2 mins then walk in front of sensors/ open close doors. The tamper restore will be sent back. Try arming/disarming. I would replace the panel battery. !
Alarm Protection Posted November 6, 2013 Posted November 6, 2013 L is low battery warning. It sounds like you have had some luck as the panel isn't locked. If the above does not work I would advise you get a pro company in to have a look. !
Adi Posted November 6, 2013 Posted November 6, 2013 as above tamper clear will be sent after an activation after its woken up, 2 mins. I really can't be ar**** with it anymore.
arfur mo Posted November 6, 2013 Posted November 6, 2013 Listen catefully - i vill say this only vonce ! You don 't need the engineer code to replace any batteries. I would change the. Control battery 1st, 3 smp 12 v from TLC Electrical or maplins. Detectors. flat batteries are indicated ny the activation LED red light flashing 3 times rapidly on sensing movement. Having done so it will 'sleep' for 4 minutes, walking into the room before hand will reset the timer back to 4 minutes. Once the lid is lifted, if or not you replace fhe CR123A battery you have to stay clear of that room for 4 minutes, then activate the detector (by walking through it.) Once the detector resets having been activated (so watch the light), only then it sends a 'tamper restore' to the control panel. The above is definative - so write it down folks If you think education is difficult, try being stupid!!!!
JregGT Posted November 6, 2013 Author Posted November 6, 2013 folks, will try this all now, all the batteries bar 1 now are new, so should I remove and replace again? As silly as it sounds the batteries are Duracell cr123 no A at the end? Would this cause any problems?
Adi Posted November 6, 2013 Posted November 6, 2013 2.5 mins arf I really can't be ar**** with it anymore.
arfur mo Posted November 6, 2013 Posted November 6, 2013 folks, will try this all now, all the batteries bar 1 now are new, so should I remove and replace again? As silly as it sounds the batteries are Duracell cr123 no A at the end? Would this cause any problems? CR123A is specified, never seen a CR123 tbh. If you think education is difficult, try being stupid!!!!
JregGT Posted November 6, 2013 Author Posted November 6, 2013 Well I must admit I seemed a little strange, same specs on the Duracell battery to the Sanyo that was removed, so I guess its just duracells way of marking up its batteries. Just changed the garage battery, so giving it 4 minutes before walking back in. Rich
