Prox Tag Lockout
cybergibbons
I now have several panels that can use prox tags to arm/disarm. Learning the tags is fine, that all works.
However, if I present an unlearnt tag to the panels, nothing happens. No warning, no response at all. If I present all four unlearnt tags to the panel, nothing.
What's to stop me brute forcing the prox tag? Is there any lockout at all?
I have a blog, some of which is about alarm security and reverse engineering:
http://cybergibbons.com/
Which panels you on about? Galaxy for example does have a parameter that will control how many wrong code attempts happen before it locks out but this is programmable and can be set to infinity.
Texecom Premier Elite 12-W and Pyronix Enforcer.
I've not changed any parameters to do with the prox tags as far as I know, though neither are as default and I have changed a lot of other settings.
Both panels I'm not a boffin on so will take a look in the engineer book. The parameter will be user code lockout or something similar as the panels don't distinguish the prox separate from a code in general terms.
Yeah, maybe I wasn't clear - just wondering what the standards say and what installers would do - I presume if it doesn't lock out, that isn't good. There might be other things stopping me brute forcing it like rate limiting, not looked in much depth yet.
I always thought with most panels a prox was essentially handled as a very long user code, i.e. loads of unknowns gets you the same alarm as trying to guess a user code.
Ion certainly locks out - for a considerably annoyingly long time - if you try and guess codes.
Am certain have had the same with prox before.
Agreed dd that as far as the panel is concerned its a user code. I might be wrong but I don't ever remember anything in the rules about what parameter lockout should be.
CG I have a feeling it will alarm if you fob it a few more times?
I think it is 6 or so attempts with ion
Me neither - might have a look tonight as interesting topic.
Anyone here ever tried to figure out a competitors eng code from a 'captured' panel?
CG are there any panels on which the code can be read straight off easily? Esp old scannys
with the removable NVM chip?
