matthew.brough Posted November 10, 2013 Posted November 10, 2013 We always crash back to defaults but it is handy if you can get in prior www.securitywarehouse.co.uk/catalog/
cybergibbons Posted November 10, 2013 Author Posted November 10, 2013 I'll have a more in-depth look in the settings then and see. Datadiffusion - I've not check the NVM of either panels for prox tag IDs. Suspect they are there are you can see the plain ID in the Windows software. I have a blog, some of which is about alarm security and reverse engineering:http://cybergibbons.com/
datadiffusion Posted November 10, 2013 Posted November 10, 2013 We always crash back to defaults but it is handy if you can get in prior Agreed, handy to see the past though, esp. disabled zones! So, I've decided to take my work back underground.... to stop it falling into the wrong hands
matthew.brough Posted November 10, 2013 Posted November 10, 2013 Funny you should mention that I was at a job in Liverpool last week and I was chatting with the security manager who said they had had tons I problems with the system but a different engineer came and cured them all. Have a guess what he did to cure the false alarms? www.securitywarehouse.co.uk/catalog/
cybergibbons Posted November 10, 2013 Author Posted November 10, 2013 Summoned Arfur using an ancient incantation? I have a blog, some of which is about alarm security and reverse engineering:http://cybergibbons.com/
matthew.brough Posted November 10, 2013 Posted November 10, 2013 Not quite. Disabled the 8 troublesome zones. www.securitywarehouse.co.uk/catalog/
MrHappy Posted November 10, 2013 Posted November 10, 2013 Summoned Arfur using an ancient incantation? lol, must be combination of jameson & neons ? Mr Veritas God
datadiffusion Posted November 10, 2013 Posted November 10, 2013 Not quite. Disabled the 8 troublesome zones. What he linked out the whole 9651!? Remember I told you about yonks back, when I worked for sparks alarm co (but a half decent one) and we got a maint and inspect on a high end (becker, bentley approved etc...) car stereo repair shop rocking an AdvantageA1? And I found every zone other than E/E with the factory wire links still in? And they responded 'yeah thanks for the ticket, cheers' and we never heard back? Went past the shop coming back from the boat the other day due to roadworks. Same shop, same owner, same Newlec bellbox!! Whats the betting still all linked out? So, I've decided to take my work back underground.... to stop it falling into the wrong hands
jiml Posted November 11, 2013 Posted November 11, 2013 We do the same lock out as for codes. I can not remember the number of the top of my head but it is like10 or 15 tags reads before we keypad tamper and lock that keypad for several minutes.
datadiffusion Posted November 11, 2013 Posted November 11, 2013 Summoned Arfur using an ancient incantation? Dare you say his name 3 times.... We do the same lock out as for codes. I can not remember the number of the top of my head but it is like10 or 15 tags reads before we keypad tamper and lock that keypad for several minutes. Sounds about right! So, I've decided to take my work back underground.... to stop it falling into the wrong hands
