Alrite guys and girls,
I have recently installed a Honeywell Galaxy G2-12 panel with 5 sensors. Everything seems to be working fine but I have now been asked to install two of the following sound bombs;
Quad Piezo Siren Sounder/Sound Bomb for Alarm Systems
I have now hit a brick wall as need to connect these two up. I was wondering whether anyone knows where the two cables go. There is a black(negative) and red (positive) go.
Please help and thanks in advance.
You got half of it right. Keep +12v where it is and move the neg wire to bell trigger, not -12v as you did which is why it rang constantly. Forget without looking in the manual but if you know where +/- 12v is it should be easy enough to work out.
Unless you want to take a photo of the terminals and I'll tell you which one.
  On 12/11/2013 at 22:13, matthew.brough said:
You got half of it right. Keep +12v where it is and move the neg wire to bell trigger, not -12v as you did which is why it rang constantly. Forget without looking in the manual but if you know where +/- 12v is it should be easy enough to work out.Unless you want to take a photo of the terminals and I'll tell you which one.
second from right I think..
  On 12/11/2013 at 22:15, matthew.brough said:
Not seen a baby g2 for a while.
you havnt seen your tool for a while either tubbs....
  On 12/11/2013 at 22:20, matthew.brough said:
You know those mirrors they have on busses like a periscope. That could help . . .
try a circus one,that's what you could be like...
Be careful you don't exceed the current rating of the output/PSU if you already have a sounder connected. You're limited to 500mA from the bell output.
Trade Member
