9448+ code change
Guest munkymush
Guest munkymush
hi, i have a 9448+ panel everything seems to be ok but it just wont let me change the user code from the default 1234,? any ideas.
thanks
Guest munkymush
Hi , either you are doing it wrong , or the "new" code already exists , as the second user or engineer.
23140[/snapback]
Guest munkymush
Does 1234 set the panel at the moment?
23145[/snapback]
hya yes 1234 does work the alarm at the moment
Guest munkymush
23140[/snapback]
23165[/snapback]
hi, ithink i am followingthe instructions but it doesnt want to play
try
6 then enter
1234
new code eg 5678 <beep, beep>
new code again eg 5678 <beep beep>
dont start your new code with a zero
James
TSS
Communication is "A question asked, and an Opinion given." I offer mine to help you with yours.
Statements I make are my personal views only at the time they are posted, if I offend you sorry, must be taken in context and do not neccesarily represent those of my employer.
Guest munkymush
try
6 then enter
1234
James
23168[/snapback]
thanks i did the 6 bit with the codes but i dont think i pressed enter after 6?
i will try it in a little while thanks a lot for your help
Guest munkymush
try
6 then enter
1234
James
23168[/snapback]
23171[/snapback]
hy, i tried it the way you suggested, but when i key in the new code i dont get the 2 beeps and it still stays set with 1234 as the code............. any ideas? thanks
Try changing to another code in case, as mentioned above, what tou want to change it to conflicts.
(You werent trying to change it 7890 were you?)
