Guest munkymush Posted September 13, 2004 Posted September 13, 2004 Try changing to another code in case, as mentioned above, what tou want to change it to conflicts.(You werent trying to change it 7890 were you?) 23202[/snapback] hy, no i was actually trying 1955 but i dont get the two beeps.........? +it still seems to stick with 1234..
Guest munkymush Posted September 13, 2004 Posted September 13, 2004 try 1971 (it was a good year ) 23210[/snapback] why 1971.?
Guest RICHL Posted September 13, 2004 Posted September 13, 2004 How old is the panel? Youre not using the second user code are you?
Guest munkymush Posted September 13, 2004 Posted September 13, 2004 How old is the panel?Youre not using the second user code are you? 23212[/snapback] i dont know the age of it.. i dont know if i'm using the second user code how do i tell.? all iknow is 1234 sets it, it seems to work ok, but i cant change the user code
Guest RICHL Posted September 13, 2004 Posted September 13, 2004 It sounds very much to me like the code you have is not of a high enough level to be able to change other codes - often known as a master code. I would suggest getting in a local engineer to clear the non-volatile memory, and giving you a new master code. then you can try changing that. Unless some of the guys on here who use the 9448+ know different of course.
Brian c Posted September 13, 2004 Posted September 13, 2004 try 1971 (it was a good year ) 23210[/snapback] If you don't know......ask.
Guest munkymush Posted September 13, 2004 Posted September 13, 2004 It sounds very much to me like the code you have is not of a high enough level to be able to change other codes - often known as a master code.I would suggest getting in a local engineer to clear the non-volatile memory, and giving you a new master code. then you can try changing that. Unless some of the guys on here who use the 9448+ know different of course. 23224[/snapback] would that be worth doing as i dont know the age of the thing or wouldi be better just buying a new panel.?
Guest Posted September 13, 2004 Posted September 13, 2004 try 1971 (it was a good year ) 23210[/snapback] great tyre that B)
Guest RICHL Posted September 13, 2004 Posted September 13, 2004 Probably no need for a new panel no, I dont think the 9448+ is more than 5or6 years old.
