9448+ code change
Guest munkymush
Guest munkymush
Probably no need for a new panel no, I dont think the 9448+ is more than 5or6 years old.
23240[/snapback]
Guest munkymush
not so long ago i had a tamper light on that wouldnt clear, so ipowered it down shorted the reset pins +powered it back up, would this have anything to do with the codes?
23248[/snapback]
[sPITS TEA ALL OVER DESK!]
23249[/snapback]
*drops cheese string*
Cheese string???
A string..... of cheese???????
23248[/snapback]
That should have defaulted the panel. Following James' instructions should now work for a code change but the system will need reprogramming
If you don't know......ask.
Cheese string???
23251[/snapback]
It's the future...I've tasted it!!
Guest munkymush
sounds like its getting close to chucking it in the bin+get another one
MunkyMush - Im sure its very easily fixable for a lot less than the cost of a new panel :yes:
