Brian c Posted September 13, 2004 Posted September 13, 2004 try defaulting it again this time make sure you short the pins marked 'RST' while at the same time applying battery power, then mains power, then remove the short. If you cannot change the code by entering: "try 6 then enter 1234 new code eg 5678 <beep, beep> new code again eg 5678 <beep beep> dont start your new code with a zero James" then you need to bin it If you don't know......ask.
Guest munkymush Posted September 13, 2004 Posted September 13, 2004 ok mate will try that tomorrow morning. thanks to all of ya for your help.
Brian c Posted September 13, 2004 Posted September 13, 2004 p.s you can get the user manual from here:- http://www.scantronic.co.uk/Literature.asp...0&optLanguage=1 If you don't know......ask.
Guest munkymush Posted September 14, 2004 Posted September 14, 2004 hi, i tried again to change the user code with no success.... so i powered it down shorted the reset pins+powered it up again as suggested. no changeat all.......... after retrying+pumping in different various numbersi suddenly got the elusive beep-beepto indicate the change of code..........(at last) somehow the code had changed. but i can now change the code to what i want. the weird bit is the process is different to the book. i now key 6 enter 1234 4digit code 4 digit code (which now bleeps twice) new 4 digit code which bleeps twice + now operates alarm perfectly. is this right, weird, or just bloody lucky.....? anyway its working and thanks alot to all for your help. regards glenn
Guest munkymush Posted September 14, 2004 Posted September 14, 2004 james said key6 enter 1234 new code ..bleep bleep new code .. bleep bleep i have to key 6 enter 1234 existing code (remember i managed to get it changed today) new code ..bleep bleep new code bleep bleep itseems to be 1 more number to key in......?? i still need to put in 1234 even now the code has changed is this right..?
Brian c Posted September 15, 2004 Posted September 15, 2004 sounds like you have changed the second user code If you don't know......ask.
Guest munkymush Posted September 15, 2004 Posted September 15, 2004 its the only way i could get it to change the code, so if this is the second user code. how do i change the first one..?
Brian c Posted September 15, 2004 Posted September 15, 2004 If you have defaulted the panel and you have followed the user instructions to change your code and it still doesn't work then I'm pretty sure it needs binned If you don't know......ask.
Guest munkymush Posted September 15, 2004 Posted September 15, 2004 it works as it is just seems that i can only have the 1 code, do ya think it'll be ok to leave it at that , everything seemsx to be working ok... regards
