bren1971 Posted November 20, 2013 Posted November 20, 2013 Hi All, Recently had intermittent problems with zone 1 front door MCT 302 contact and now has stopped working altogether. Tried battery change, magnet change and contact itself flashes the 8-9 times when cover removed etc. Alarm is in memory and showing 'not ready' and 'front door open' status when queried. Zone 1 seems to have disappeared as only showing zones 2-9 during diagnostic test. I went to re-enrol zone 1 but the option to 'enrol wl device' is missing from option tree in installer mode (all other options are there)? Any help/advice much appreciated.. , Brendan
james.wilson Posted November 20, 2013 Posted November 20, 2013 Can you delete the device and re enroll securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted November 20, 2013 Posted November 20, 2013 Sounds like a possible faulty contact. Replaced one this morning actually. Does the contact flash when you open the door?
bren1971 Posted November 20, 2013 Author Posted November 20, 2013 Can't re-enrol as the option to 'enrol wl device' is missing in the installer/enrolling menu? Yes, possible faulty contact - doesn't flash when magnet /door opened (reed switch may be gone)? But - if I buy another door contact - still have the enrol issue....
sixwheeledbeast Posted November 20, 2013 Posted November 20, 2013 IME the reed switch is fine you can hear it click, but it will always show OPEN. You have to "enroll sensor" and press off to delete the zone you are replacing.
james.wilson Posted November 20, 2013 Posted November 20, 2013 Bit if its already enrolled would it remove the option. Are the other zones showing the enroll option securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
sixwheeledbeast Posted November 20, 2013 Posted November 20, 2013 Bit if its already enrolled would it remove the option. Are the other zones showing the enroll optionIn "ENROLLING" there is a menu called "ENROLL SENSORS" You know a device is enrolled as when selecting the zone it says "Press OFF to DEL" I don't recall a "enroll wl device" option. TBH the menus are so straight forward, I don't even keep a copy of the manual anywhere to double check.
bren1971 Posted November 21, 2013 Author Posted November 21, 2013 Thx six, so I've deleted zone 1 and re-enrolled it as per above by removing cover of the contact. In this state it says system 'ready' however when I re-tighten cover on the contact it reverts to not-ready and door open?
bren1971 Posted November 21, 2013 Author Posted November 21, 2013 So even though it transmits to panel to enrol etc the contact tells panel it's open when door is closed and still no light when magnet is removed ie when I open and close the door.
james.wilson Posted November 21, 2013 Posted November 21, 2013 Id say the contact is faulty then securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
