Tmd15 Digital Detector!
dazoman1
We use them .
Not to replace a contact tho but in certain places to give confirmed and reduce cabling.
Not had any issues so far .
We use them in the same situation as above, we never spec them on a new install, but handy if confirmed is required on an upgrade  etc.
Fine if using CC / EOL but absolute pain in the hoop if the installation has iD installed.
Only problem i have found is when fitted in a warehouse and the concrete floor is cold the DT side seems to fall asleep and is hard to trigger.
*concrete floors are always cold but i mean winter time with no heating.
