Ac Bleed
Must have been advanced for its time I suppose,
IIRC around 25yrs ago stuff started to get modern features of time & date logs & lcd displays ect...
TS700 came after CPA6's TS2000 & TS800 ect... & was the low end "networker" panel
Yes it had a networker style 4 digit rkp
That's a bad idea, this would cause an earth loop.
Also just think how noisy that mains earth would be from EMF and RFI.
Thought that myself. Under maint until this year.
That's a bad idea, this would cause an earth loop.Also just think how noisy that mains earth would be from EMF and RFI.
that would be one if my concerns, but more so if you got a earth elsewhere, it could bypass a zone or tamper.
old school was to make 8 - 10 turns coil around a small screwdriver to act as a 'choke' in each core at the panel.
IIRC around 25yrs ago stuff started to get modern features of time & date logs & lcd displays ect...TS700 came after CPA6's TS2000 & TS800 ect... & was the low end "networker" panel
Cricky - you will be romancing about lace wiring and t&b frames next :o)
