How To Program Galaxy 512 Outputs
party2
Hi friends,
I'm security systems technician and found a Micro tech Galaxy 512 panel in object which I need to program to transfer alarm at monitoring station. These panels are very rare in my country:)
So I'll use Gsm transmitter (inputs controlled by negative impulse). Need to transfer only common alarm signal, no OPN/CLO. Panel divided in two partitions
In 53 cell was able to change outputs polarity, but they are stable after alarm. How to program outputs to transmit NEG only after alarm ?
No. 2 output looks like dry NO/NC relay to me, maybe I can use this?
So if I understand what you want is that you just want to send an trigger when the alarm has activated.
You mention the system is in 2 groups, do you want 1 output to trigger if either group has an alarm or do you want 1 output to trigger if 1 group is activated and another output to trigger if the 2nd group is activated?
Yes, correct, need to send a trigger after alarm.
Just need output to trigger if either group has an alarm
Ok, follow these steps
Engineer Mode>Menu 53(Outputs)
Choose output and press enter
Select 1 = OP Function
Select 4=Intruder and press ent
Just check in option 3 - output polarity that it says POS. I think it defaults to that. If not just invert it so it is.
Press A to move down to option 7 O/P Groups and press ENT
Make sure all the groups you want to respond are selected. If you are using 2 groups I am assuming you are using groups A1 and A2?
That's it.
