Led Floodlights
jnealon
Im looking to replace a few 500W halogens with led floodlights.
Anyone used them or recommend a supplier, thanks
just say as yet i have not seen any that match a 500 watt, i'd rate the biggest ones i've seen which i think were 70's as 300 watt ish!
ok at 1st floor but a bit narrow and less effective if up in the eaves of a 2 story. if for a client then best warn them, then remmind they are far cheaper to run and should last a lot longer (as long as the case holds out).
i got some ebay ones and I can confirm, the cheap substitutes are as they are described CHEAP... I re-wired mine internally put an earth to the casing and transformer, re-sealed then  wired on a ring with flex and quickfit power connectors... back to a plugtop on a timer they have worked well for nearly 4 weeks ill take some photos.
  • 3 weeks later...
Why don't you try for the Cosco, or directly throught eBay, Amazon !!
I'd installed each one of these and it really works great,,
Info,,
Avoid the 'warm white' types, unless you want background lighting. Tends to be a very yellow wash, like the early energy saving bulbs.
  • 4 months later...
That's probably the frequency.
Eta, of the LED
