matthew.brough Posted December 11, 2013 Posted December 11, 2013 Yes. I didn't know if needed or not so I went on the side of caution and defaulted each time. I'll give him a call and see if we can get it working. www.securitywarehouse.co.uk/catalog/
AdrianMealing Posted December 11, 2013 Posted December 11, 2013 Yes. I didn't know if needed or not so I went on the side of caution and defaulted each time. I'll give him a call and see if we can get it working amealing@texe.com Head of Industry Affairs Visit Our Website Texecom
sixwheeledbeast Posted December 12, 2013 Posted December 12, 2013 i would flash the panel up to the last release of the Premier firmware which was 9 something, i can send it to you if you want...Check the downloads section ... http://www.thesecurityinstaller.co.uk/community/files/file/1150-premier-48-version-1006-firmware/ http://www.thesecurityinstaller.co.uk/community/files/file/1143-premier-version-1000-firmware/ Make sure you use the correct version firmware or you'll brick the panel.
breff Posted December 12, 2013 Posted December 12, 2013 You have to be careful which panels you flash, boards pre v8 have to have an extra nvm fitted IIRC, and some early boards cant be flashed past v7 The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
sixwheeledbeast Posted December 12, 2013 Posted December 12, 2013 You have to be careful which panels you flash, boards pre v8 have to have an extra nvm fitted IIRC, and some early boards cant be flashed past v7Yes, that is a good point, definitely had issues with a 640 having a lack of NOVRAM after flash.
AdrianMealing Posted December 12, 2013 Posted December 12, 2013 Yes, that is a good point, definitely had issues with a 640 having a lack of NOVRAM after flash. You have to be careful which panels you flash, boards pre v8 have to have an extra nvm fitted IIRC, and some early boards cant be flashed past v7 Correct on both counts, this is a version 8 so all should be well. amealing@texe.com Head of Industry Affairs Visit Our Website Texecom
datadiffusion Posted December 12, 2013 Posted December 12, 2013 But worth bearing in mind for the one I was tinkering with on the bench, thanks the advice all, I will check the V no. on that one before I brick it... So, I've decided to take my work back underground.... to stop it falling into the wrong hands
james.wilson Posted December 12, 2013 Posted December 12, 2013 is there any protection that stops that, ie flashing a board that will be bricked? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
matthew.brough Posted December 12, 2013 Posted December 12, 2013 is there any protection that stops that, ie flashing a board that will be bricked? I heard you have more bricks than a house builder www.securitywarehouse.co.uk/catalog/
james.wilson Posted December 12, 2013 Posted December 12, 2013 you heard wrong sia doesnt use texecom securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
