Texecom 24 Not Big Enough
jumpdyke
in my van days i had loads of gal 60 chips. i used to use them on 18's as the 18 was a bit **** but the 60 was great.
imo still the classic gal was better assuming 4.06+ sw than an g3 or dimension
I'd agree those g3s seem particularly buggy. Got one I can't clear a fault message on which seems a known issue so a g2 is going in to replace it as it's only small and fe duo if the grief now.
They all use the same micro now. They didn't pre-Elite.
Correct, with the exception of the 640, the only other difference is the size of the NVM hence the different memory maps and why you can flash them with the wrong firmware, but also the reason they won't work correctly.
amealing@texe.com
Head of Industry Affairs
Visit Our Website
Texecom
The Classic and Dimension are not that different except for alerts really?
From a user perspective no, from a hardware design there is a huge difference.
Plus the classic was better imho
I agree, very stable compared to it's modern day equivilent. Not sure there will be that many dimensions that stand the test of time as the classic did.
Look on the bright side James, if demension PCB's were that good I wouldn't have had to buy 3 replacements from you in recent months :)
