Rte On Bpt A200/n
timmo66
Unfamiliar with BPT kit.
Fitting a switch to override gate opening/closing..
For those of you with a wiring diagram to hand, am I right to wire the switch between 5 + 9 on the handset side of the A200/N?
I also confirm, short between 5 and 9
