Issue With Visonic Powermax Complete
bloxta
Hi all
I have just installed a Visonic Powermax for a friend today but am having trouble clearing down an alarm on Zone 3, I have gone into diagnostics and it is seeing the detector no problem at all, also it is reporting CPU tamper, bell tamper but they are all clear and working. I powered the system up last night at home and it was working fine (I set/unset and triggered alarms off much to the missus delight)
Having spent many years installing hard wired systems with very little issues I am keen to start fitting these little beauty's as they arn't as labour intensive and don't create too much mess.
Your help will be greatly appreciated
Power max has been discussed here a few times and I think your trusted cabled systems might be your friend here if you want to keep the hassle free systems you've been enjoying or choose an alternative wireless system. The new tex 12-w gives the freedom of wireless without the greif similar gear creates.
Assuming the OP used to install the Veritas anyway, it would be a doodle to switch to the 12...
  • 3 weeks later...
