520C Gd
al-yeti
Hi
I am trying to connect to the panel via rss but i keep getting wrong password, as you know eventually the panel will signal, can you remember the options where i can find the password its looking for, i not a galaxy expert so would appreciate the help, i have all other access codes thanks
The RSS password cannot be found anywhere in the menu system. It's programmed using RSS.  There's only one way of getting it out that I know of and it's a bit convoluted.
ah mr G didnt expect you to reply, you know who i am (ethernet card?)
anyhow this panel is fresh, i tried default passwords but it came from ADT stock do you know there default rss codes? i tried the 9*****....... and the 5****....... but no go
Pretty sure ADT don't set an RSS password in defaults.  Press 'enter' when prompted to "Enter password for account".
Please share as I have just taken over an estate from the Yellow box guys and can't get in due to password/remote code
