Hi,
Total newbie and novice to all this.
I've recently had to do a full reset of the system to find reset the engineer code as it was lost/forgotten.
I've since had a flashing bell sign on the keypad and I've tracked it to be the battery tamper.
I've took a picture of the board as there is a light by the side of the terminal where the battery connects.
Can anyone help as I'm unable to use my alarm
Flashing bell is a tamper, check you have closed the panel lid correctly also check the spring and white bit of platic is still on the tamper switch (tamper switch is a black button in the mid hottom of the main pcb)
Close the panel lid slowly and check you can hear the tamper switch click those panels did have a habit of the switch jamming they also tended to have faulty tamper switches on times aswell, if its only a flashing bell its 1 of 3 things that could be in tamper either panel, keypad or external siren
  • 9 years later...
Hiya.. seem to be having a problem much the same after changing the battery.
I've done this before and noted how to reset.. but the panel flashes a bell and nothing seems to clear it.. tried your above fix and still the same.. any other ideas would be appreciated.  Thank you in advance.
