Re-Commission Required On Scantronic 9827
djbobbins
Hi
We had a kitchen refurb done for which our alarm control panel and main box had to be disconnected.
The kitchen fitter has reassembled it all but the alarm now sounds as soon as the power supply is reconnected.
I'm hoping this is a case of it being able to be recommissioned rather than replaced but would be grateful for any advice.
The control panel is a Scantronic 9827 and we're just outside Warwick. I know the system is now probably a bit long in the tooth but until the kitchen work it had been fully reliable for the seven years we've been in the house, so i'm reluctant to go down the replacement route if that can be avoided. Happy to pay sensible money for someone to come out and do the honours on this if that's feasible.
Thanks in advance.
Will
Enter your code after power up. which should stop the noise,
you may need an engineer if it has been setup with engineer reset.
Hi Will
Welcome to the forum
Where are you? your location will make a difference on the charge
Not sure that is actually an option for the 9827, eng reset only that is...
DD- not sure off the top of my head.
Will- To be honest id take the chance now and upgrade the system. Look for local SSAIB OR NSI companies
Charges may vary between companies, it's not allways the best idea to go with the cheapest.
Eng reset was on a 9800, which launched 1989 ish ?
The prospect of "recommissioning" a vintage alarm for "sensible money" which has been tinkered with by a kitchen fitter must have our Warwick members in frenzied use of the PM system ?
Its OK what I've done there is read 9827 keypad as 9427 like on the 9448... Need sleep...
You were - it was!
