Honeywell Ag6 Clicking After Storm
blinkysirens
Why was recommending an upgrade not a constructive answer?
Poor diagnosis imo, could be a simple fix.
I think you need to go back and read the comments.
The film you star in is on later. I've always liked the christmas carol . . .
If you read the OP it's apparently been tested and all working at the moment.
Still doesn't mean I wouldn't recommend an upgrade.
just to add my 2p diy worth of advice , yes put it in skip even i wouldnt touch em, but in case of the fault suggestion above sounds right , hold of voltage to low or not there, you went out came back, bell used up the internal battery , but then again i went for a repair once where the customer panicked couldnt remember the code, so opened the panel (one of those weird MDT panels mini) disconnected battery removed the mains and back up battery and waited till the bell switched off
and was left with a click click click.....
wheres the skip!
