al-yeti Posted December 30, 2013 Posted December 30, 2013 hi anyone know the pinouts for header so i can connect? rss i dont have a lead for it i can make one i guess
al-yeti Posted December 30, 2013 Author Posted December 30, 2013 come on, all experts sleeping in lol
matthew.brough Posted December 30, 2013 Posted December 30, 2013 A case of most of the experts don't play with such baby panels. Most experts probably using SIA rather than pins negating the need for the lead . . . www.securitywarehouse.co.uk/catalog/
al-yeti Posted December 30, 2013 Author Posted December 30, 2013 ok but i dont want to have to reset the whole panel to get the codes out, so you suggest just direct connect to the tel port?
matthew.brough Posted December 30, 2013 Posted December 30, 2013 Your taking it over and you you want to crash the user/engineer code? If so there is an easier way to do that. www.securitywarehouse.co.uk/catalog/
al-yeti Posted December 30, 2013 Author Posted December 30, 2013 yes correct, i dont know the other way but i have software easy enuf on the g3 dimensions etc but havnt done it on these before,
matthew.brough Posted December 30, 2013 Posted December 30, 2013 Just realised this thread is public. We don't give out this info in public forums for obvious reasons. If you apply for trade status http://www.thesecurityinstaller.co.uk/forum-trade-access.html you can get the answer on the raft side and you'll see many more posts that you currently can't see. www.securitywarehouse.co.uk/catalog/
MrHappy Posted December 30, 2013 Posted December 30, 2013 hi anyone know the pinouts for header so i can connect? rss i dont have a lead for it i can make one i guess IIRC the factory lead is needed as its neither 232 or 485 at the header pins, Mr Veritas God
al-yeti Posted December 30, 2013 Author Posted December 30, 2013 i sent you a pm Mathew, ok i assumed the rss uses 232, because the programming header uses the rss
