3MSW Posted December 31, 2013 Posted December 31, 2013 I have an 8SP 400 Accenta mini G3 with remote LED key pad and 5No Texecom Veritas Reflex PIRs. I have just moved one of the PIR's but had to disconnect the 6-core cable from the PIR to pull it through the joists. Now I have connected it back up (correctly I assure you) none of the PIR's are registering anymore. I have both the engineers code and our set/reset code plus the manual but there is no obvious way of getting it to reset - is there a simple way I can reset it to get it working again? Any help would be appreciated.
norman Posted December 31, 2013 Posted December 31, 2013 Sounds like you have blown a fuse. Nothing is foolproof to a sufficiently talented fool.
Alarm Protection Posted December 31, 2013 Posted December 31, 2013 The fuse in the panel has blown. Please beware there is 240v present when you remove the panel lid. !
3MSW Posted December 31, 2013 Author Posted December 31, 2013 Thanks, tested them all and Fuse F3 (1A to protect the Speaker 13V supply) is blown. I'll get a replacement fuse tomorrow and test.
sw46 Posted January 9, 2014 Posted January 9, 2014 Have you got a complete tyamper circuit? if not, on the G3/G4 type panels they will lock you out.
