Redswanny Posted January 5, 2014 Posted January 5, 2014 Hi, could someone please help me. I have recently moved into a house with the concept 6 fitted ( no maual or codes left by the previous owner), following some advice on line I have managed to get power to the main box amd download a basic user sheet, however when I power up I get a costant alarm sound and only the power indicator on the panel, all other buttons respond when pressed i.e. beep but no effect. No other lights show on the panel. thank you in anticipation
PeterJames Posted January 5, 2014 Posted January 5, 2014 You need to put a valid code in. As above if 0123 doesn't work and you don't know the code you need an engineer, it wouldn't hurt to get it serviced if its been down powered a while
PSE Posted January 5, 2014 Posted January 5, 2014 The basic manual you have downloaded is what it is, Just 2 pages to it. The default code is on the manual, also the steps to reset it if the user code is lost
datadiffusion Posted January 5, 2014 Posted January 5, 2014 Google result No. 1 shows you everything you need, indeed. But an engineer will be able to make sense of it, but be warned a very old panel and some may refuse. So, I've decided to take my work back underground.... to stop it falling into the wrong hands
MrHappy Posted January 5, 2014 Posted January 5, 2014 the controls are cira 20yrs old, normally if its powered down when you move into a property there's a reason personally I'd bin them, before binning them I'd prove the wiring attached & bin the detection devices too, if you want to prove the controls put links all the zone & run the rkp off a fly lead & have all the tamper closed. Mr Veritas God
arfur mo Posted January 13, 2014 Posted January 13, 2014 never been a fan if the concept panels, but have you asked your estate agent if they have the code or can contact the vendor? If you think education is difficult, try being stupid!!!!
ChrisMurphy Posted January 14, 2014 Posted January 14, 2014 check with your insurer, you may have misunderstood their "requiremets" for the alarm. Often they only recognise alarms worked on by an approved installer (ssaib or nsi) 30 years of experience, ssaib approved family business. We have a very long list of clients that we are very proud chose to use us. We have never bought out any other company or forced anyone to use us. All of our customers are free to leave us whenever they wish, yet very few ever have. This is down to the fact that we always put our best into every job. http://alarmguard.co.uk
Cubit Posted January 14, 2014 Posted January 14, 2014 check with your insurer, you may have misunderstood their "requiremets" for the alarm. Often they only recognise alarms worked on by an approved installer (ssaib or nsi) ??
arfur mo Posted January 14, 2014 Posted January 14, 2014 check with your insurer, you may have misunderstood their "requiremets" for the alarm. Often they only recognise alarms worked on by an approved installer (ssaib or nsi) i'm living proof that is not so, depends on their own risk assessment as to if they insist. If you think education is difficult, try being stupid!!!!
