Gent Vigilon Delay Block ?
whizzer
i cannot seem to clear the fault and delay indicators on a Vigilon , i have sorted the original faults on the system but cant seem to clear the delay ?????
the printer needs paper but i dont think that clears the delay indicator when refilled, any ideas ?
not a panel I really know but what faults are showing
no faults as such just the fault and delay indicators.
it is something to do with "delay blocks" but im not sure how to remove it.
have you looked at display active,have you re allocated the loop,what was the original faults
this delay indicator has been on since i first looked at the system, the last fault was a device which i replaced and that cleared.
what menu should i check or change for display active ?
it's the display active menu,it's not a panel to mess with it can go all very wrong very easily..
sorry ! yeh i will check it out and see what the settings are, just wondered if anyone else had overcome the issue because i am sure its a common problem unless your used to the panel.
Anything Gent is a nightmare. This and Fike (Rafiki) Sita are very similar as designed by the same folks. Just like  goncall said, things can go very badly very quickly. Give the tech line a call.
  • 3 weeks later...
card 15 being the printer lol, delay block being lit is not a problem, it could be for plant shut down (may be delayed for 2 minutes  incase of false alarm) or could be sounders in a hospital to allow investigation time or a school, could be on comms to prevent the big red bus coming out for a couple of minutes if someone burnt toast or a public building where a millicious alarm could be activated in say a shopping center etc
if delays are setup, they should be documented somewhere in the paperwork, i always leave a sheet in the panel with special instructions like delays, shutdowns, comms etc,
Employed by an NSI GOLD company
Any comments or views i have are my own, and do not represent that of my employer or clients.
