trigster Posted January 25, 2014 Posted January 25, 2014 Hi, I'm after some advice, having looked at the Menvier SD3 which i have been told is compatible with the 9751, i'd like to ask if others have could recommend anything else? The SD3 is obviously a decent piece of kit but its got a hefty price tag to boot. I'm only after something to send out a text message on activation, i don't really need to talk to any would be burglars via the phone! thanks Simon
matthew.brough Posted January 25, 2014 Posted January 25, 2014 Indeed and I don't think really worth the money as you are putting blind faith that it will actually work especially when you could have a proper arc monitor the alarm for 2 1/2 years for the same money via a GPRS only connection. www.securitywarehouse.co.uk/catalog/
al-yeti Posted January 26, 2014 Posted January 26, 2014 Diy? http://www.ebay.co.uk/itm/GSM-SMS-Automatic-Security-Alarm-Dialler-ESIM021-/130831988 And fit this in addition http://www.ebay.co.uk/itm/Honeywell-ADE-8EP276-A-UK-Informa-speech-dialler-/161151886557 Both cheap enough to fit for any installation, txt and dialup done together don't trust gsm on its own But like the man said if you setup it up you could arc it instead http://pages.ebay.com/link/?nav=item.view&id=130831988661 Other link dead try this one for gsm
trigster Posted January 27, 2014 Author Posted January 27, 2014 thanks al-yeti i've opted for one of the products you recommended so will see how it goes. Simon
