matthew.brough Posted January 26, 2014 Posted January 26, 2014 I can accept the microwaves could cross talk causing an issue. What set the pirs of then being dual techs? Agree optex know their stuff. We used to use them prior to Aritech and extremely reliable detectors. www.securitywarehouse.co.uk/catalog/
sixwheeledbeast Posted January 26, 2014 Posted January 26, 2014 Well if the the bottom PIR's can FA I don't see why the top ones can't? A DT is no good if the MW is mostly active.
al-yeti Posted January 26, 2014 Author Posted January 26, 2014 I see , they all going in seperate locations should be ok, set to trimode I think
sixwheeledbeast Posted January 27, 2014 Posted January 27, 2014 I see , they all going in seperate locations should be ok, set to trimode I think That's ok if your not wanting confirmation.
al-yeti Posted January 31, 2014 Author Posted January 31, 2014 I think I like them went in well, however why doesn't antimask transmit on contact ID?
sixwheeledbeast Posted January 31, 2014 Posted January 31, 2014 I think I like them went in well, however why doesn't antimask transmit on contact ID?If they go into mask then surely the panel is at fault.
Adi Posted January 31, 2014 Posted January 31, 2014 why would you need to transmit anti-mask I really can't be ar**** with it anymore.
al-yeti Posted January 31, 2014 Author Posted January 31, 2014 I thought idea was if someone masks it during an unset mode that it transmits I guess internal alert is fine just wondered if it's possible to make it send the info
olijones11 Posted February 3, 2014 Posted February 3, 2014 Depends on ur panel, and what resistor you've selected in the detector, if they don't match then it won't signal. Also they can be a bit temprimental unless the anti mask dial has been set up correctly
