al-yeti Posted February 5, 2014 Author Posted February 5, 2014 ok can i post installation manual here? because the manual says as normal that the resistors 1k/1k , and then 3k for mask/fault (in pyronix manual that is) now above its says mask should be 12k , where does it say 12k for mask in the galaxy , page number? Also please note the panel itself does detect the masking with the above setup
james.wilson Posted February 5, 2014 Posted February 5, 2014 Not in public no. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
olijones11 Posted February 5, 2014 Posted February 5, 2014 No not the mask, mask is 3k on the jumpers, some detectors have a fault resistor in them too, the detectors put it into the circuit if they fail their self test, that resistor is 12k on the galaxy, and shows up as a fault on the keypad hope that's a bit clearer
al-yeti Posted February 6, 2014 Author Posted February 6, 2014 Ah yes , sorry I lost the plot I should not used the word fault when reporting mask, earlier comments I made confused myself, your correct mask is one issue which panel reports and fault is when self test occurs and reported as fault if you need it to, via a 12k resistor pack marked anti-masked or just a fault if you get me, but lol I get you thanks for the correction
olijones11 Posted February 6, 2014 Posted February 6, 2014 The 12k resistor packs are marked as fault
al-yeti Posted February 6, 2014 Author Posted February 6, 2014 Er 12k marked as anti-mask resistor I send you picture if you want hee hee
norman Posted February 6, 2014 Posted February 6, 2014 The 12k resistor packs are marked as fault I know that's why I sent them all back! Nothing is foolproof to a sufficiently talented fool.
matthew.brough Posted February 6, 2014 Posted February 6, 2014 Galaxy's need a 3k for mask, plus the normal 1k EOL and 1k Shunt, and usually a 12k for fault, and there's no option to select masking to send over the dialler only using an Ethernet card What? You can send the exact same events over the dialler as you can the ethernet card, external telecoms mod, ISDN, internal RS232 or external RS232. I know that's why I sent them all back! My gut is aching with laughter www.securitywarehouse.co.uk/catalog/
norman Posted February 6, 2014 Posted February 6, 2014 That's some ache. Nothing is foolproof to a sufficiently talented fool.
datadiffusion Posted February 6, 2014 Posted February 6, 2014 I know that's why I sent them all back! Only just got it! So, I've decided to take my work back underground.... to stop it falling into the wrong hands
