4 Camera System Advise Please
richard3009
No but the thinking is any cable promotes a (water) bridge between the skins?
That job I did yesterday with the GJDs, they are going to have a massive damp bill,
and I really am wondering if its to do with where the new wires have been fished through
from the new CU up the cavity in the (buried in the hillside at back wall) garage?
They've already had the CU changed to an IP rated hager type, but that clearly isn't the answer...
Mounting the cameras at high level will do nothing apart from give you the top of someone's head.
I usually install the IR Domes at bedroom window level, Drill into the cavity at 45 degree to the roof, then Super rod an external Cat5 to the loft
This way leaves not even 1" of cable on show externally, Makes a fantastic finish to the job
Customers are still amazed to this day, they always say, Where is the cable. Its not on the outside or the inside.... How you done that.... Magic
How do you get out of the top of the cavity?
With our 1994 built house, you don't... :(
Thick plastic sheet cemented at the top, when fitting my BBs I had to drill all the way.
Any distance from the soffit less than the length of the longest sds, forget it!
Easy, Lift the first row of tiles to expose the rod
Doesn't work for every house, just forward plan and check the tiles first
The reason i ask, and as sata has pointed out, the cavity should be sealed at the top, usually brick on edge or slates, its only recently building regs has changed and the top of the cavity remains open but the cavity batts/insulation must continue out the cavity and across the roof space with no gaps so as there is no thermal bridge.
If the cavity is open at the top its down to dodgy builders.
There's that tangent again
I disagree cctv is done in many ways and one of them is an overview of the area, mounting cameras low isn't always the best way better to mount high and low
All about budget if you can't afford having them both then read the tangent
Sorry but I thought wiring was not allowed through the cavity and that the meter tails were the exception , unless that's changed
Normally out of the big gap?
Of course I'm being facetious.  Some are capped, some are not.  You can stitch around the capping (we had to do this recently in a thatched bungalow).  I believe you're not meant to use cavities any longer but (except the bell) you're only going from inside and up and there is a big hole all around so I don't see the problem.  Newer houses aren't an issue thanks to the flood of wireless *****.
My pet hate is bells jammed up to the soffit, round here there is one by a local firm (or, could have been rescued from a skip)
where you can only see half of it from a distance :)
talking of wireless *****, anyone tried the new ricochet pa?  i have to quote 1 on a job.
