Outlook
timmo66
I receive emails to my work inbox for two different email addresses, can I assume then that I can send from two different addresses too?
If so, how do I choose between the two?
Yes
Create the two accounts in Outlook, then for sending, simply highlight the relevant account and when you create new email it will default the sender from the highlighted account.
Alternatively, simply click new email then you have the option to change sender as the 'from' box will have a drop down option
Just bear in mind that changing 'sent from' addresses alone can cause some over cautious email servers to reject email...
I have been the victim of this a few times.
It might have been that @number10.gov.uk address you were using . . .
  On 02/02/2014 at 18:07, datadiffusion said:
It worked though. I got off all those parking fines...
No, that will have been due to the Barrister you needed to argue the finer points of Law.
It worked though. I got off all those parking fines... invoices
You mean those non vat compliant invoices.
