Another 9448 Question
Old Nick
I have set Zone 3 as an entry/exit zone - Zone 3 is situated at the top of the stairs and I wish to isolate this zone for nightime use etc.
When I set the alarm at night it seems to set OK with the change of tone, but as soon as the Zone 3 pir detects movement it triggers the alarm, which then has to be unset.
Zones 1 and 2 are also set to entry/exits.  The system only has 3 zones plus a magnetic contact on the front door.
Again help would be appreciated.
it should not normally be exit entry, but on only when 'B' is pressed. go to it in engineer mode and press 'b' which will then flash in the display sequence, also set it to 'night' zone.
Apologies for the delay in replying to your suggestion.  This version of the 9448+ does not have a numerical keypad, but the good news is that I have now found the correct method of excluding one zone for overnight alarm etc.
Again many thanks for your help
regards
Nick
