Scantronic 9800
hi all
I am currently recommissioning a scantronic 9800 as this is my first proper alarm system I am wondering how to connect the pir's to the control panel
thanks
If youre planning on turning this into a career then fill yer boots a good panel to have a play with, but if this is just a one off, you may struggle with the 2 digit display, when it comes to programming.
Also unless already replaced youll soon have trouble with the nvm (one of the chips inside).
Id spend a tiny bit of money on a 9651 and have the full manual etc...
Google is your friend.
As I say if its Modern era the nvm will fail at some point and the system will alarm randomly even if unset and probably not respond to a code.
ok thanks
the modern alarms programming book I found in a box in a charity shop lucky there reading Information about the system it was installed in 1992 and is not the modern rebadged one and where can I buy a new nvm chip from as I have reset it and it is working fine but I will replace if necessary
thanks for your help
