mob315 Posted February 17, 2014 Posted February 17, 2014 I am wanting to install a magnetic door sensor for a cupboard which is constantly monitored whether the alarm is set or unset. Ideally with a hidden switch for when I want access; understand this can be done with the zone in PA or fire mode but would it be possible to install a 3-terminal rocker switch in this or would it cause an activation when the switch was flicked? Any advice would be greatly appreciated! Thanks
MrHappy Posted February 17, 2014 Posted February 17, 2014 Id assume a boxed passswitch parallel to zone would be the easiest way to achieve this Mr Veritas God
sixwheeledbeast Posted February 18, 2014 Posted February 18, 2014 Tamper would be the best zone type to use on the Veritas. Zone Omit Module? Definitely something with a key and a tampered enclosure.
