Gd520
al-yeti
These days?
There was a days when engineers in the field were as good as us or am I living in la la land?
Second new keypad was duff aswell weird put a third on came straight up after exit
Nah, don't believe it - unless you have damaged them during the install.  It's more likely that the suspect keypads aren't as tolerant to your unstable bus / voltages.
laughs up sleeve ..
I just tried my spare at home works fine, are you guys sure that specific addresses are not required on the 520 as it's specified on the manual certain addresses on certain lines unless I am confused
Eg actually to long to give and can't post manual lol, galaxy dimension quick guide gives you addresses you can and can't use I think that's when I used my spare I didn't pay attention to address, other keyprox only adds one keypad and then doesn't respond so
seems only one keypad faulty and the smart Rio low voltage which I need to look at
+12v paralled????? Inbound 12v why we need it?
I thought you don't need to take 12v from panel otherwise what's the point of having a smart Rio?
Unless you mean is there an inbound from the panel connected to the output of the Rio? Nobof course not lol I am quote sure of that because from the panel only the data goes to it and screen and it was a keypad fault with address I issue
As for the smarty Rio we will have to see
laughs up sleeve ..
You can accuse me of many things but by tech knowledge is top notch.
:no:
Not April the 1st is it?
maybe,but self praise is no praise
