Scantronic Ion 16 Two Way Radio Fob
Justin Wood
So I was installing a ion 16 today at work for a client. Now I don't have much knowledge on this panel. Now I've added two way radio fob on. But when I set the system with it it asks for code same with the part set. But when alarm is set the unset button unsets it without a code? So basically I want it so when I push the full set button it starts setting the system and the exit timer starts. Any help would be much appreciated
System options, user access, 2w set instant. Is this option set to yes?
