Security Warehouse Eco Dvrs 1 Of 2
datadiffusion
Security Warehouse Eco 4 Channel Budget DVR
Introduction
Search for ‘4 Channel Analogue DVR’ on the internet and you’ll find more results
ll not die and ironically you can now even get analogue DVRs in almost stylish white
iMac mini type cases, aimed at home use; although they don’t feature things like RS485.
It could be argued that ICs like the Sony Effio series or the 960H format have pushed
analogue into realms of quality not envisaged 5 years ago when IP was seen as the
best way forward, squeezing that extra bit of performance out of analogue video with
little difference in cost for the camera, as opposed to IP where entry level is still at a
high price and even using a PC or server as the DVR, good software is not free.
post-4216-0-36886600-1393588067_thumb.jp
Price though, is a major plus for the Security Warehouse Eco 4 channel DVR.
Specially sourced, this entry level unit nevertheless offers a lot of features, and is
a true professional grade product for the same price as a restaurant meal for two.
But it turns out the low price doesn’t put it the same league as other (often dearer)
dubious online offerings with brand names you’ve never heard of – far from it.
This line of DVRs comes in 4, 8 and 16 channel varieties, and on all but the entry
level 4 channel version you get hardwired alarm inputs, per-channel loop through,
and twin HDs. All versions feature common software, full D1/960H recording and
HDMI monitor support.
In the box
The DVR, hard drive screws, SATA lead, manuals, CD-ROM, UK IEC lead, PSU,
remote control handset, USB optical mouse.
Setting up
Adding the hard drive is simple, although requires basic tools, and then setup can
be completed rapidly. The Linux based OS fires up in seconds, and the drive was
formatted within a minute or two. No issue at all with recognition of the drive.
DHCP worked fine but I went for a static address, and then added a dyndns.org
username and password with no issues. The netviewer software connected straight
away on Windows 7 (64 bit), the GUI of which is identical to the IE or Mac Safari
web interface – just note that it’s not currently Chrome compatible. Pleasingly, the
ipad and iphone software worked straight away and, after a couple of minor issues,
neither of which have ever occurred again, so did the android. A windows phone
app is apparently in the works, but there is no indication of when. Bear in mind settings
can only be changed with the webserver or the netviewer software, or of course the unit
itself. Suffice to say when using the unit directly, with the supplied USB mouse, all
orks well; interaction and response to menus etc… is instant.
The back panel
post-4216-0-43203100-1393588039_thumb.jp
In use
It took only about 10 minutes to have everything set up the way I wanted it; i.e.
permissions, users, motion recording etc… There are options for motion activated
emails too; on this 4 camera unit, no hardware alarm inputs. There was definitely no
need for a manual and the only slightly annoying thing is the ‘line by line’ setup for the
cameras etc… rather than seeing them in a grid or table fashion, but there is a copy
function that comes in handy. Many budget competitors are no different in this respect.
Retrieving footage is a doddle and even the most ‘challenging’ customer should have
no issue with this, remotely or otherwise, it even ‘talks’ you through it. The timeline is
a little hard to navigate when reviewing motion captured footage until you realise you
can ‘zoom in’ by using the scroll wheel on the mouse. Watching all 4 screens in sync
is of course not an issue. Footage can be easily exported to a USB stick.
Under the hood
Running a Linux based operating system, the quality of the PCB and components are
as good as any other I’ve seen. The PCB was clean and the SMT components neatly
arranged; nothing skewed or covered in stray flux or glue. There are no fans on the 4
channel model.
Software
Logging on with netviewer 2.0…
post-4216-0-41752100-1393588640_thumb.jp
Netviewer in use… (The IE web browser look and feel is the same)
post-4216-0-67112100-1393588641_thumb.jp
Rxcam for ipad, iphone, and android…
post-4216-0-97815900-1393588643_thumb.jp
Long term test
I’ve had my test system up and running for over a month now, and have been
very happy with its operation.
Whilst my cameras aren’t yet where I’ve wanted them, i.e. outdoors, the motion
detect facility has worked well when they have been tripped in their temporary
location. I’d have no problem using this for my own customers, and will be using
it permanently on my own house alongside some demo Axis units.
Summary
I would not hesitate to install this system where required for a budget system; at
the right discount level you’ll find it less than anything else comparable out there.
What’s great?
1.    The price – I haven’t seen anything at this price point that performs so well or built as well.
2.    Quality images – this doesn’t feel like a cheap, low res budget DVR.
3.    Ease of use – you won’t get the customer phoning up in a pickle from a simple operation like reviewing footage.
4.    Step up to the HD-SDI models and the interface is identical, no learning how to operate it all over again.
Worth pointing out…
1.    PSU on this 4 channel version feels a little lightweight. It’s more money, but I’d be half
tempted to change it on some jobs for something a bit more substantial. That said, there
have been no issues so far.
2.    No support for Chrome browser, however, IE and Mac Safari does and there are
plenty of reliable and externally maintained tablet and phone apps, which work perfectly.
3.    Competition – whilst most rivals at this price will be utter junk, the likes of the barebones
Alien range are not that far away. Reassuringly though, this exact same DVR under a brand
name sells for twice as much at most outlets to the public; an ‘all in one box’ kit based
around this DVR is also sold at some “trade only” electrical wholesalers for a much
higher price per component. Being offered it at the Security Warehouse price allows
you to still do a pro job for less than the sparky.
Room for improvement / wishlist
It would be nice to be able to upload a logo and change the colour scheme (currently any
colour you’d like, as long as it’s green) to suit your corporate colours. Ditto an ‘installer
only’ area to protect and lock such choices.
The configuration screens for some of the options could be tidied up so you could see
all chosen options at once. But, this isn’t enough to put me off.
Manuals and CD-Rom aren’t great; bit Chinglish, but not essential.
Conclusion
A great value budget DVR that might be useful as an upsell to an intruder system or
as a replacement for an older system where you can’t persuade the customer to go for
anything higher spec.
Specification
Display Resolution
PAL: 960×576 @25fps (each channel, Frame)
Record Resolution
PAL: D1 mode 360×288 (CIF),720x288 (HD1), 720x576 (D1)
960H mode: 480×288 (WCIF),960×288 (WHD1), 960×576 WD1
Record Speed
PAL: (each channel) D1 / 960H mode: 25fps
Playback Channel
1/4 Channel
Playback speed simultaneously 8CH Record
PAL: (each channel) D1 / 960H: 25fps
Mobile Surveillance
Mobile Phones view based on  iPhone, Android, Windows Mobile (TBA) & Blackberry
post-4216-0-30184900-1393588809_thumb.jp
Hope this helps!
  • 5 months later...
it doesnt its a bare machine. most people want to use desktop drives, some want to use red drives, some want to use full on enterprise drives. so i decided it better if the installer fits their own, that way they can choose. plus i wont be able to buy drives much better than an installer.
  • 2 weeks later...
  • 2 months later...
