james.wilson Posted March 4, 2014 Posted March 4, 2014 If it were the tamper you would get a tamper alarm. are you using a different setting program now securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Jigsawbitmissing Posted March 4, 2014 Author Posted March 4, 2014 Hello James, I am using exactly the same settings as before. I get the quick bleeps with the setting fault. It does not say that the tamper alarm has been activated. I get the indication that the alarm has been set and the short bleeps to indicate that. I then have a minute to exit the property. I have been checking the settings all morning, the delays and everything seems okay. :confused:
james.wilson Posted March 4, 2014 Posted March 4, 2014 if the landing sensor is activating on the exit route it needs the same circuit setting as the hallway in the set group, ie 1, 2 or 3 securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Jigsawbitmissing Posted March 4, 2014 Author Posted March 4, 2014 Hello James, I am lost now and will have to admit defeat I think. I will call someone out over the weekend. I bet it's a small thing that needs doing as well!
Jigsawbitmissing Posted March 12, 2014 Author Posted March 12, 2014 Hello All, Just to bring everyone up to date with this. I telephoned Honeywell who said that the "fault" will show if any of the PIR's are tripped whilst setting the alarm. Once the PIR beam is unbroken it goes back to it's normal set. One solution that was offered was to point the PIR away from the door entry/exit but in my mind that defeats the object if someone does break in. I think I can live with the setting fault if the PIR beam is broken whilst exiting. Thank you to everyone who gave me advice on this.
Scotmod Posted March 12, 2014 Posted March 12, 2014 You're getting the setting zone fault because the zone hasn't been programmed as an Entry/Exit route. The tamper circuit on these panels is global so there is no problem with the detector, it is due to programming. Since you have installed it yourself I will assume you will have the manual with it, it's a basic panel and the change will take you all of 5 minutes. These are very basic panels and it's a very basic fault.
datadiffusion Posted March 12, 2014 Posted March 12, 2014 Good old manufacturers giving E/U direct installation assistance... So, I've decided to take my work back underground.... to stop it falling into the wrong hands
matthew.brough Posted March 12, 2014 Posted March 12, 2014 Good old manufacturers giving E/U direct installation assistance... I thought that. Disgraceful www.securitywarehouse.co.uk/catalog/
Scotmod Posted March 12, 2014 Posted March 12, 2014 It's honeywell grade 1 units. They won't give a monkeys.
Jigsawbitmissing Posted March 12, 2014 Author Posted March 12, 2014 Hello Scot, Data, Matthew, E/U? Does that mean end user? Thank you Scot, I will check the Zone settings to make sure it's set as Entry/Exit route.
